Intermittent RPM/Power loss at speed
Old Oct 20, 2023 | 08:48 AM
jimvw57's Avatar
My speedo never showed the VSS was sending crazy signals. I connected an autel and watched the vss signal, it dropped to around 35mph when the engine was cutting out, then would start working again. I replaced the vss and it has worked fine ever since.
Old Oct 20, 2023 | 08:51 AM
disco96sd's Avatar
Classic VSS - had it myself - get a LR part don't go cheap
Old Oct 20, 2023 | 10:26 AM
WaltNYC's Avatar
The speedo "filters" the signal so the dial won't bounce around erratically. Look at the MPH reading on the OBD to determine what the ECU is seeing.
The hex bolt which holds the VSS in place is in a weird area. Access is impeded by the parking brake cable. I forget what size it is (3/16 IIRC), but the main thing is to get a LONG hex driver. Like 6" or something like that. The job will be MUCH easier.
Old Oct 21, 2023 | 11:21 AM
Shiftonthefly1's Avatar
Gentlemen.... seriously I cannot thank you all enough. It goes to show that no matter how much experience you have there's always more to learn.
It was the VSS failing. I honestly thought w out the erratic speedometer it was a definite no VSS issue. Well I was dead wrong. I swapped it out w one from my parts stash and a 100 miles later it's still going good. That was definitely it. I'm still going to buy a new part and swap it if necessary.
Thanks again
Old Oct 21, 2023 | 11:34 AM
Harvlr's Avatar
That’s great! Something to put in my back pocket for future use.
mgbjimmy
Jan 17, 2021 08:45 AM
mcdoof
Aug 3, 2020 04:06 PM
keoni004
Nov 4, 2012 05:06 PM
maudlinp
Dec 29, 2010 07:19 PM
96Disco
Oct 16, 2009 12:20 AM
