Issues while greasing the drive shaft
Hello all,
I am base lining a new-to-me Disco. Most of the items on my list I have never attempted before. I was greasing the drive shaft joints and have some questions about the results.
First off, is this normal/good for the grease to come seeping out of the rubber boot like this?
Second, when I started greasing the zerk on the front joint, grease immediately shot out of the tip of the zerk fitting. It seemed like the pressure was pretty high inside.
Last, when I started greasing the rear joint zerk fitting, black grease started shooting out of the joint ends:
Is any of this normal, abnormal, signs of impending doom?
You want to see new grease coming from around all 4 seals. One of the important reasons to grease u-joints, if not the most important reason, is to purge all the moisture and impurities out of the u-joint. You can only achieve that when new grease comes out from around all 4 seals.
