Just got our first disco,does it need modds
Old Jan 20, 2012 | 05:05 PM
Christina Jon Harrington's Avatar
thanks i live on highway 26 by mount hood its crazy this time of year.as far as a lift im not to sure on only thing i have found on lifts are 3 inch lifts and they are like 400 bucks and 3 inches is not that much id rather waste money like that on a 6 inch or more,as for the bumpers i really like the arb bumpers but i also like the trimed look of a factory bumper but i cant have the winch right and a winch would be good for me and my wife becuase its really not alot of fun chaining up in almost 3 feet of snow when its 20 degrees any ideas on mounting a winch to the factory bumper
Old Jan 20, 2012 | 05:07 PM
also is there a way to get more movement in the stock suspension like swy bar removal or something like that there is a tone of trails up here on 26 with rocks and river crossing but i no i dont have enough flex to get over this stuff
Old Jan 20, 2012 | 05:12 PM
Danny Lee 97 Disco's Avatar
Once you take the plastic off and see what the "factory bumper" is, you will understand. It is so flimsy, the only winch it could accomodate wouldn't help you out of much.
A six inch lift on a Disco is absurd. It would throw off everything in the driveline and you would regret it.
If it running on the original springs they are sagging by now. You are better off to buy new HD extended springs (2 inch) like Old Man Emu or similar and top quality matching shocks and good tires and that Disco will go places you will not believe until you see it/ do it.
Old Jan 20, 2012 | 05:14 PM
chris bob i bought the truck from a land rover dealer and they said every thing has been maintainced i also had jiffy lube do all the fluids in the truck the day after i bought it just to be sure that every thing was good and the guy at jiffy lube was like 200k holy crap this thing runns like new he tould me the only thing he thought would need to be serviced was the steering pump becuase it was leaking anyways also i replaced a few vacum lines..the one thing im wowed about is that i got this truck for 2500 bucks and i dont know if its a good buy.also i dont care to much to rebuilding the engine in the next year or so as i just rebuild the motor in my wifes escorts 4 months ago so anyways with all that being said i think ima go get the heeater in tha garage going and start cuting up the bumper happy rovvering lol
Old Jan 20, 2012 | 05:17 PM
true i know a guy that builds the trailing arms to correct the angles but he said im on my own finding springs i think ill have to try a 2 inch this summer and if i dont like ill go bigger btw thanks for all this advice
Old Jan 20, 2012 | 05:23 PM
EricTyrrell's Avatar
2 inch suspension lifts are common because they don't require much modification. You just needs springs. With 3 inch and above you may need to do a U-joint or double cardigan conversion with extended brake lines. The more you lift it the more the suspension and steering geometry is affected and the more expensive it gets to correct it. RTE Fab sells a 3inch kit for about $2000 that includes everything you need except shocks. Also, the more you lift it the more likely it is to roll over.
You can remove the sway bar but it can be dangerous on-road. The other option is to get a sway bar disconnect kit from Lucky8.
Old Jan 20, 2012 | 05:35 PM
thanks eric what part of southrn or are you in maybe we could wheel sometime bein oregon really isnt that big
Old Jan 20, 2012 | 05:47 PM
2 inch Body Lift Kit - Discovery. - LR-Dy-2 - Discovery - Land Rover - from Xpajun - 2 inch Body Lift
i think a fresh set of springs and a set of these would be best sence the suspsion is already to notch and maybe a bushing set i was just under the truck and my fron bushings are looking a little dry
Old Jan 20, 2012 | 06:09 PM
I'm in the Grants Pass area. Body lifts require stiffer springs since the stock are too soft. If you're getting stiffer springs then you might as well get +2inch springs.
Old Jan 20, 2012 | 10:43 PM
tweakrover's Avatar
Looking at the first pic, it looks to me like you might have a lift already, its hard to tell from a pic but it seems to have a little more room between the tires and fenders.
