Just a Little confused?
Old Jun 6, 2011 | 04:46 AM
skatelove303's Avatar
Default Just a Little confused?
Im replacing my U-joints for the second time and im going to be replacing them with the same ones as last time with a greaseable Zerk. But it says on the prop shaft rebuild i only need three? Shouldnt i need 4? Any specific U-joints i should be looking for? Can i replace that 4th spot with a regular u-joint?!
Old Jun 6, 2011 | 08:06 AM
antichrist's Avatar
Read this
https://landroverforums.com/forum/ge...rebuild-29302/
Old Jun 6, 2011 | 09:42 AM
jafir's Avatar
Some discovery series 1 only have one ujoint at the transfer case side of the rear driveshaft and a rotoflex coupler at the rear end. Some have a ujoint at each end. If you are doing front and rear driveshafts, by a joint for every place you have a joint.
Old Jun 6, 2011 | 11:19 PM
So on my hunt for U-joints today i called countless parts stores to finally end up with checkers ordering them to be in tomorrow. But i would like to share something completely ridiculous with you, The bearings i ordered were 22.99. They also had some 11.99 ones but were poor grade. In my search i found a range of around 20-55 dollars for U-joints. . . And then i called Land Rover Denver South. And they quoted me 127 dollars for ONE thats one UNIVERSAL joint for 127 dollars. HAHAHA Who is that stupid!?!?!
Old Jun 7, 2011 | 07:15 PM
antichrist's Avatar
Advance Auto Parts has made in USA u-joints for about $12.49. PDQ 1-0005, as listed in the link I provided.
Several in the Denver area have them in stock.
Old Jun 8, 2011 | 02:22 AM
I went to the advance in littleton and they told me all they had were 2 that ran around 26.99 a U-joint. So i told them No. I finally got them through checkers for 11.99 and have installed them So thank you guys, Im glad i got that done!
pbmaxb
Mar 10, 2010 08:27 PM
Spike555
ROAMING WITH FRIENDS
Dec 14, 2009 08:04 PM
Night Train
Jun 3, 2009 06:04 PM
Brad S1
22
Sep 14, 2008 10:59 PM
javoli001
Dec 10, 2007 01:33 PM
