Just now bought a 96 disco!
Old Jun 3, 2021 | 01:01 PM
WaltNYC's Avatar
Originally Posted by panicofthedisco
Thank you so much for this. I’m checking eBay now, I definitely like to try fixing up before any shop.
just download it (and the electrical manual, owners manual, etc) from the google drive link in my signature. Print out what you need when you need it.
Old Jun 6, 2021 | 01:28 AM
Robert Booth's Avatar
Does it tick when cold or when warmed up?
if it ticks when cold, it might be a lifter.
if it ticks when hot it could potentially be the slipped sleeve issue.
Old Jun 11, 2021 | 01:08 PM
panicofthedisco's Avatar
4wd High
[QUOTE=Robert Booth;777245]Does it tick when cold or when warmed up?
It ticks when you turn it on. Its a constant ticking sound
Old Jun 14, 2021 | 02:06 PM
JohnZo's Avatar
Even after changing bearings, lifters, camshaft and such, my 96 ticked for a couple minutes cold, then stopped while it heated up, then ticked again at temp. Drove great, sounded like a diesel engine at times, long term fuel trim was over 11%. So, while checking for vacuum leaks, I spotted some weeping where the lower plenum joins the intake manifold. I got busy and resealed the plenum to manifold. To my great surprise, the ticking stopped. LT Fuel trim went nearly 0%. Now it drives even better, and all my worries about worn piston slap were a waste of time and mental energy.
By the way, if you don't know what a valve hydraulic lifter is (16 cylindrical pieces per Rover V8), maybe this isn't the rig you need. I'm sure this forum could help if you ever decide to put it up for adoption. RPI Engineering has lots of info and experience with these engines regarding the weakest links and write ups for common parts to replace. You could spend a ton of money just on the motor if you decide to. Or just keep up with oil and filter changes and drive on.
Happy trails and best of luck anyway. No need to panic...
fire771087
Mar 19, 2012 11:43 AM
kman3786
May 25, 2010 11:46 AM
DiscoSam2
Oct 29, 2008 11:26 AM
systek
Jan 15, 2008 01:07 PM
madison263
Jun 21, 2007 07:20 AM
