key problem
Old Feb 21, 2011 | 05:40 PM
Lolagurl's Avatar
Unhappy key problem
I got a 1998 land rover and it has a problem with the key.
it wont come out of the ignition unless the car battery is diconnected or dead. i know there's a switch that you could turn off or something and itl work just fine but i dnt know where its located or if thats the problem..
anybody knows what i can do???
Old Feb 21, 2011 | 06:12 PM
Long Haul's Avatar
Try popping off the wood trim piece on the shifter and tightning the cable up, its probably loose and the sensor still thinks its in gear.
Old Feb 21, 2011 | 07:35 PM
What LongHaul said.
Old Feb 21, 2011 | 09:59 PM
jafir's Avatar
On my D1, I would just push up harder on the shifter and the key would come out. When I pulled that cap off, there was no cable adjustment... I think the cable attached with a clip or something. There was a big nut the held the handle on. If you tighten it too much, the then button no longer moves smoothly.
Old Feb 22, 2011 | 09:25 AM
groundandpound's Avatar
That "big nut" is what comes loose and is what needs to be tight - not OVER tight.
I have the D1 as well, and experience the same issue. You need to slide the retaining clip off to get a socket on it, but once tightened, you will be good to go.
Old Feb 22, 2011 | 11:44 AM
Lolagurl's Avatar
alright ima chek that out and see if its that
thanks everyone !!
Discolife
Nov 25, 2011 11:38 AM
freelander2002
Oct 27, 2009 05:07 PM
pilsner
Apr 7, 2008 03:24 PM
plastique999
Jan 22, 2008 01:34 AM
Jay
Apr 27, 2005 03:49 PM
