keyless remote
Old Feb 6, 2011 | 08:14 PM
rover11's Avatar
Default keyless remote
I just purchased a 97 Discovery. The po did not have the factory key. I'm assuming the Discovery has some sort of factory alarm of some sort. Can i just buy a key and have it cut and programed?
Old Feb 6, 2011 | 08:21 PM
jafir's Avatar
on my 96, the key and the remote (plip?) were separate. There isn't a chip or anything in the key, so as long as you never lock with the the remote (which should be easy, since you don't have it) you should be able to use a cheap copy.
Old Feb 6, 2011 | 08:25 PM
rover11's Avatar
Thats the thing, I want to be able to lock and unlock it with a remote. Would any new Discovery I remote work? Are they programable?
jafir's Avatar
http://www.roverparts.com/Parts/YWX101230A.cfm
I guess you need a dealer computer to program it. On the 94-95 with single button remotes, I guess you can program it yourself (with a helper).
http://www.roverparts.com/Instructio...g_AMR3722G.cfm
Old Feb 6, 2011 | 08:27 PM
rover11's Avatar
Would that work with a 97? Or was it different in 97?
Old Feb 6, 2011 | 08:29 PM
jafir's Avatar
the 96+ D1 is the first link, two button. It says you need to program it with the computer. The second link is for the older style. I guess they wanted to make it more secure on the newer ones? either that or they wanted to make more money for the dealers.
Old Feb 6, 2011 | 08:31 PM
Locking the drivers door with the key arms the alarm, you do not need the remote to use the alarm system.
Yes you can have a copy made, IVECO 4? is the key blank you want.
Just Google it.
If you get the genaric blank any key shop and cut it for you.
Old Feb 6, 2011 | 08:32 PM
rover11's Avatar
http://cgi.ebay.com/ebaymotors/LAND-...#ht_582wt_1141
Old Feb 6, 2011 | 08:36 PM
Thats the remote.
Old Feb 6, 2011 | 08:45 PM
jafir's Avatar
Looks just like the one I had on my 96, where the lock button is worn smooth so that I could never tell which button to push.
Frank4
Mar 21, 2014 05:21 AM
cowgirl1989
Feb 18, 2007 11:54 AM
onid888
Nov 28, 2006 09:21 AM
btp226
Jun 3, 2006 08:24 PM
djronv
Freelander
Mar 14, 2006 04:13 PM
