Knocking from brakes
Old Jan 24, 2011 | 08:06 PM
thehun's Avatar
Default Knocking from brakes
This is weird...I just did a brake service...and now I started a knocking sound but if i press the brake even a little it stops completely...everything was torqued down to spec so i have no clue what can cuase this
Old Jan 25, 2011 | 08:03 AM
So, tear it down and see what you did wrong.
Old Jan 25, 2011 | 09:16 AM
kenk's Avatar
Just pads or rotors too? If you replaced the rotors also, could be in the hub/bearing.
Does it make the sound all the time when driving or just over bumps?
Old Jan 25, 2011 | 10:44 AM
Soccer Dad's Avatar
In mine the brake pad backing was "floating" and slamming onto the caliper housing. The pad was lifted by a sticky section of the rotor and hit the upper side and fall back and hit again wearing out a groove. the fix was to replace the whole caliper. yeah right!
I now insert a tiny spacer in between and the knocking is gone
Look at the brake pads to see if they "float" up and down. the new pads might be a tiny smaller.
If they float, I'll draw a picture of the spacer
SD
Old Jan 25, 2011 | 03:16 PM
thehun's Avatar
new bearings..yes it does it all the time below 50mph...i got new bearings and all..ill check the pads..i did have one piston that was frozen..i wonder if that is sticking
mowensmd
Aug 21, 2024 11:07 AM
FightOnUSC79
Nov 26, 2010 09:43 AM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
disco1
Mar 3, 2006 10:29 AM
