Landrover Discover V8i 3.5
Old Feb 19, 2022 | 03:53 AM
Anthea's Avatar
5th Gear
Default Landrover Discover V8i 3.5
Good day,
Could anyone help with advise, my father in-laws Landrover overheats as soon as he drives uphill, when he goes downhill the heat seems to come down a little. What could the problem be?
Thanking you in advance
Many thanks
Anthea
Old Feb 19, 2022 | 07:44 AM
stillruns's Avatar
Fan clutch, lack of coolant, etc. Others will chime in that know more than I do.
Old Feb 19, 2022 | 09:27 AM
JohnZo's Avatar
Plugged radiator lower section can be diagnosed if the lower section stays cold when the upper section is hot.
Maybe you just need to drive faster! Fan clutch problem is more apparent at low speed or in line at a drive-thru.
Old Feb 19, 2022 | 02:52 PM
Fan Clutch or radiator having restricted flow are a pair of the common reasons
Eren Can Köksal
Dec 28, 2020 11:08 PM
xisled
Jan 13, 2017 01:11 PM
Paula Ludlam Westnidge
Jul 27, 2014 06:48 AM
bigmuddy
ROAMING WITH FRIENDS
Feb 10, 2008 12:46 PM
master
Freelander
Jan 17, 2008 09:26 AM
