Largest size tire for LR Discovery1
There are a million and one threads on this exact same topic, it has been discussed/debated ad infinitum. However, here are the basics:
Wide tires might look good but the suck gas, destroy your turning radius, tuck worse off-road, and cost more. But hey, pick your poison I guess.
30s will definitely fit.
31s will probably fit, chance of trimming.
32s will fit with trimming and a 1-2" lift.
33s will likely require full cut-out fender flares and/or a significant lift.
This may help: https://landroverforums.com/forum/se...earchid=836877
Basic Tire Information - Land Rover Forums : Land Rover and Range Rover Forum
best thing ive found for tire size
Depends on who you talk to. Wider tires believe it or not do not make a huge difference on gas but the height does because how much the engine has to work to turn it. As far as off road performance people will argue force per square inch vs total contact pattern. Honestly I believe tread and height is what makes the difference in how an off road tire performs. This is why my next tire will likely be a super swamper Q78 or pitbull rocker
235/85/16 = 31.73" x 9.25"
265/76/16 = 31.64" x 10.43"
245/75/16 = 30.46" x 9.64"
Same off road performance? Probably not. Every little bit helps, right? That's why people go to a 255/85/16 vs a 265/75/16.
As to the OP's question. A 245/75/16 is about the biggest you'll get on a stock suspension, and you still may need to trim a touch. There are a LOT of other factors involved in determining what tire you can fit. If you leave your sway bars attached and never go off roading a 315/75/16 could work on a 2-3" lift. On the other hand, Jake is running 35's on a 3" lift but has done a ton of trimming and covered it with flares. But his truck articulates extrememly well. Then there's a truck like mine that runs 265/75/16's on a 2" RTE lift. I did moderate trimming(Camel Cut) and can flex quite well. My truck with open diffs out wheeled a D2 running 285/75/16's and traction control easily.
Like I said there's lots of options out there and lots of things to consider when choosing a tire size.
Bigger is not always better.
I did moderate trimming(Camel Cut) and can flex quite well. My truck with open diffs out wheeled a D2 running 315/75/16's and traction control easily.
On a side note, knowing what I know now I would cut and go for a skinny 33" on a 2" lift and no flares if I was not going to re-gear. There is SO much room in the wheel wells as long as you get a body saw or have an extremely steady hand with a grinder you can make it look clean.
There's always D2 fender flares but you can ask Turf how much he likes his now
