Left side lights won't cut on with headlights!
Hey guys. Changed my rear/left brake light a couple of days ago. I noticed when my wife drove off from the house that when the headlights are turned on, it won't come on. But when the brakes are pressed the light comes on. Is it a bad fuse or did I hit a wire maybe? Need a little help. Thnx people!
The tail light assembly, with connector C406, where you change the bulbs, has a common ground for all the bulbs. The fuse for brake light is F1, the fuses for the "side light" (I call them tail lights) are F2 and F8. may have to change more bulbs.
The right side is fine. It's only the rear left tail light. It comes on when I press the brakes. But when I cut the headlights on the top light is supposed to stay on bu t it's not. Are you saying it might be some bad bulbs causing it? Just trying to understand
The bulb comes on when I push the brake. It's supposed to stay on with the headlights and get brighter when I press the brake with the headlights on! I believe! All I did was change a bulb. Also the yellow light near the front on the left side doesn't come on also! Weird!
