Let's play... WHAT'S THAT NOISE?!!
Old Dec 26, 2014 | 10:04 AM
TOM R's Avatar
Run a compression test
Old Dec 27, 2014 | 02:15 PM
Gimebakmybulits's Avatar
If you can get it to start, pull plug wires one at a time and see if the knock goes away.
Old Dec 28, 2014 | 10:44 AM
bmwrovers's Avatar
ok.. dropped the y pipes and gonna have the cats checked (potentially just gonna cut them out as this rig is exempt from emmisions)... then dropped the oil pan and found a small piece of hard plastic in it, but that's not enough to make the noise, the pickup screen was clogged 99% with the RTV the previous owner used to seal the pan (what a mess), and pulled the bearing cap off the cyl. in ? and very slight wear on the bearing surface... not sure where to go now... i have a new oil pan gasket, so i'm gonna stop that slow leak, but since i didn't find anythin earth shattering, i'm back to square one with why it's not starting and what that knock was. possibly the cats burned up and are clogged to high heaven, but what were the chances both were clogged that much, i would think the engine would still run, albeit poorly, off one bank... oh by the way TomR, compression test was ok (done before i tore it apart further)
orangechicken
Oct 9, 2014 08:26 AM
russburcham
Jun 26, 2014 11:48 AM
Phatrowles
Feb 8, 2013 09:28 AM
mwindth
Jul 30, 2011 10:24 AM
flygirl92
May 15, 2007 07:28 PM
