Leverage Gets The Lugs Loose
Old May 24, 2011 | 12:02 PM
Danny Lee 97 Disco's Avatar
Default THIS is what I do.
Like Tom, I also used a slight bit of never-seize on the lug studs.
I replaced my screwed up "Capped" LR dressy lug nuts with the solid style ones used on the RR Classic. Never have to worry about the caps again!!
I also bought one of the 4 way lug wrenches from Advanced Auto for about twenty bucks. It is great for loosening any tight lug nut, just make sure it has a 1 1/16 inch socket made on, since that is the size a DI uses. I just need to fix something to clamp it in the back cargo area.
A four way lug wrench is hard to beat. Do not allow the idiots at a tire place to pound away on your lug nuts and make sure they have the correct size socket or they will screw up those fancy shiny caps.
And the lug nuts should always be loosened prior to jacking the wheel off the ground.
robot808
Nov 18, 2009 11:10 PM
J_McCrea
May 20, 2007 11:05 PM
Brad S1
Jul 12, 2006 04:51 PM
bmwrovers
Tires
Nov 18, 2005 10:33 PM
bmwrovers
Jul 18, 2005 02:24 AM
