license plate fasteners? and Other questions
Old Aug 16, 2014 | 10:43 AM
philwarner's Avatar
Default license plate fasteners? and Other questions
Got my new license plate yesterday; what fasteners fit the mounting holes?
Interior lights don't come on when the driver door is opened, but do for all other doors; is there a switch or setting for driver door yes or no? Front interior lamp is on "auto" position.
What all should light up for the bulb check when you first turn the ign key on? Should the Dif Lock light do a bulb check?
Still can't get the T case to shift out of high or to dif lock, so I'll be pulling the boot and foam insert to check. Ran across this interesting youtube video on the subject that shows what the dif lock linkage should do. An interesting watch and listen.
Planning to charge the AC today. The compressor runs but there's not much cooling so I assume it is low; I do have the gages and Vacuum pump in case it is really empty, but hope it just needs a can added.
Old Aug 16, 2014 | 03:37 PM
TOM R's Avatar
Pull the pin switch in drivers door jamb to see if it is connected, mine is not and the wire is too short to fix it
Diff lock lite is not on for bulb check
Just brake, oil, srs, batt, check engine,seat belt, low fuel
Saw that video before guy is funny, mine was hours to fix had to remove the whole thing and beat it apart it was so siezed , it was the actual shifter not the little pivot he point to
Check that your a/c fans run and tilt the rad back debris likes to get between it and condensor to restrict air
Old Aug 16, 2014 | 04:33 PM
TOM R's Avatar
Lp bolts on door are metric
Old Aug 16, 2014 | 06:56 PM
philwarner's Avatar
Originally Posted by TOM R
Pull the pin switch in drivers door jamb to see if it is connected, mine is not and the wire is too short to fix it. Diff lock lite is not on for bulb check Just brake, oil, srs, batt, check engine,seat belt, low fuel
Thanks, Tom,
Now that I know they are metric I'll see if I can chase the license plate holder threads; they probably had some 1/4-20s or sheet metal screws forced in them by a PO to screw up the threads.
I took out the driver door pin switch and found the wire had come out of the connector; it took awhile but I was able to fish the wire out and found out you shouldn't try to solder the wire back on with the connector still on the switch, though. I knew better but the connectior was stuck on and I got in a hurry and the metal spade end popped off the plunger and it and the spring flew out. I crawled around for half an hour to find the darn spring. Surprisingly it went back together and held, so all doors turn on the inside lights now.
I wish the left side repeater wire was as "easy" to find; that light was gone and I've fished and fished with a bent coat hanger and can't find the lamp holder or its wire. I replaced all the other burned out lamps except brake lights which I found are not working so I didn't get to the AC since having brake lights seems more important than being cool.
Any suggestions on checking the brake light switch? I have the cruise brake switch off and am about to tackle the light switch, but should probably check the lamps first to make sure they are not all just burned out.
Shipwright's disease seems to have set in; the more I fix the more I find
Old Aug 16, 2014 | 07:27 PM
TOM R's Avatar
Push the hazard and walk to rear, should be 4 yellow lights blinking
Turn on ign. Turn on head lights, push the fog/hold the fog lite button by the tach till it lights
Walk to rear top red on both tail lights should be lit these are rear face fogs
Have someone push brake pedal with ign on to check rest
On front the big yellow lens is only turn signals, same with fender side lights
When you have the headlight switch in the first spot that is what we call park lights, rover calls em city lights, either way it turns on 1 tiny glass bulb in each headlight housing
Plus the red tails
Wish my wire had enough to reach the pin to fix it
To remove tail lights there is a panel on each side in rear then 2 plastic nuts on each light, pita to remove em, ESP if you have rear a/c like me
Old Aug 16, 2014 | 10:39 PM
philwarner's Avatar
Check
Turn on ign. Turn on head lights, push the fog/hold the fog lite button by the tach till it lights. Walk to rear top red on both tail lights should be lit these are rear face fogs
Check
Nope, Nothing (it's in a dark garage so I can see if they come on)
On front the big yellow lens is only turn signals, same with fender side lights. When you have the headlight switch in the first spot that is what we call park lights, rover calls em city lights, either way it turns on 1 tiny glass bulb in each headlight housing Plus the red tails.
Yep. I replaced one of the little headlight "city lights" and several of the side lamps today.
Wish my wire had enough to reach the pin to fix it. To remove tail lights there is a panel on each side in rear then 2 plastic nuts on each light, pita to remove em, ESP if you have rear a/c like me
Yes, a pita. Probably why the left one only had one nut on it. Unfortunately the left taillight unit bulbs are all good, including both filaments of the tail/brake lamp checked on the connector pins, and still no brake lights. All the fuses are OK too, so back to the brake light switch tomorrow.
bcolins
Jun 5, 2011 09:21 PM
ajh
Oct 10, 2007 10:16 PM
underpsi
Jan 15, 2007 01:20 AM
RDM3
Freelander
Dec 15, 2006 04:56 AM
KWAYZ
Dec 7, 2006 09:09 PM
