Lift Kit Shock Absorbers RESCUE PLEASE!!!
Well it appears that I broke the front passenger side shock absorber while using a ratchet wrench on the upper bolt located on the shock tower. Heard a loud noise and saw fluid spewing for the absorber! The upper portion of the shock dislocated itself from the lower portion. As a result one end of the shock is still stuck within the tower (I was able to remove the entire shock tower complete with the upper portion of the shock still attached) and the other end is still attached the the axle. I was able to remove the spring which in itself suffered no damage... So Before I continue working of the lift I need serious advice. I have every intention of saving the remaining shocks but I need to revise my procedure! Please help!!! Ill upload a short video clip in an hour of the situation.
On a second note... are these shocks repairable? Can they be screwed back together and filled with more fluid?
http://www.youtube.com/watch?v=azQMCHGQXI0
Good luck!
