LIFT/SHock question
Old Jan 26, 2013 | 11:04 PM
Discolife's Avatar
Default LIFT/SHock question
Our suspension was totally rebuilt, I am buying HD Spring that should give us 2 inch lift from stock
The shocks are brna dnew and feel great.
When I get the HD springs do I HAVE to buy shocks too? Or can I use my current ones?
Old Jan 26, 2013 | 11:16 PM
Discolife's Avatar
DO I need to buy spring isolaters all around too?
Old Jan 26, 2013 | 11:29 PM
antichrist's Avatar
No, you don't necessarily have to buy new shocks. Depending on where you drive though you might want to install limit straps like the Series Rovers had so your shocks aren't what's limiting the axle drop. It can break the shocks. It all depends on the compressed/extended measurements of your shocks.
Old Jan 27, 2013 | 10:21 AM
If you only drive on paved roads, dirt roads you will be fine.
If you flex the axles to max travel you will over extend your shocks.
If you are on a budget and doing it one thing at a time, just stay on road and you'll be fine until you can buy longer travel shocks.
Old Jan 27, 2013 | 07:37 PM
Discolife's Avatar
what about those rubber spring isolaters? do I need new ones on each corner?
Old Jan 27, 2013 | 11:16 PM
XCELLER8's Avatar
fwiw...I put new ones on mine and I cant say that I feel any difference....I suppose if the old ones were really trashed then you might want to replace them.
The guys are right about the shocks...normal driving ....no big deal, but the bumpier it gets the more likely you are to "top out" the shocks (pretty annoying )
ShadowMerchantBC
Aug 12, 2011 08:02 PM
dan240
Jan 12, 2010 10:58 PM
avking
Jan 23, 2009 08:27 PM
