Lifter, Exhaust Leak, or other Problem?
Old Jan 17, 2018 | 05:20 PM
jwlehman's Avatar
6th Gear
Question Lifter, Exhaust Leak, or other Problem?
Hi,
I have a 98 Disco I with 254K miles. I replaced head gaskets and cleaned up the heads at 104K and the engine has run like a top since then. When I started it a few days ago there was a popping / clicking noise from the right side of the engine. It sounded like an exhaust leak but I can find no sign of that. Also checked plug condition and plug seating on that side of engine, no issues. I did find that if I pull the spark plug wire off the #8 plug (right side of engine, furthest back), the noise almost completely disappears. The noise can't be heard after the engine reaches about 1100 rpm.
(I also discovered, inadvertently, that if I left the entire right bank of the engine disconnected from the ignition coils the engine could be started and actually ran. Who knew!)
Do you folks have any ideas about what may be causing this noise? Thanks for looking at this post.
Jeff
Old Jan 18, 2018 | 11:06 AM
WaltNYC's Avatar
Something like this? I found this to be a spark plug that was partially cross threaded and not fully seated. Some plug sockets cannot fit well. The exhaust manifold can get in the way.
Old Jan 19, 2018 | 12:14 PM
jwlehman's Avatar
6th Gear
Thanks for the video Walt. It's the same area of the engine certainly and a similar sound. I'll take another look at the plugs. Since the noise disappears when then engine rpm is raised just a bit I'm also going to check oil pressure. It's about time for an oil change and the oil level is near the bottom of the OK range on the dip stick.
twin6
Feb 19, 2017 02:16 PM
Luckyjayb
Dec 22, 2016 01:14 PM
WaltNYC
Jul 27, 2015 02:24 PM
roverbob
Mar 19, 2012 10:09 AM
bdiseati
Freelander
Jul 22, 2010 09:12 PM
