Lifter Noise After Head Job
Old Mar 26, 2022 | 02:27 PM
DiscoNewbe's Avatar
Originally Posted by JohnZo
My 96 4.0 GEMS had noise after rebuild. Sounded just like valve tick. I finally tracked it down to a vacuum leak between upper and lower plenums. But that was after I got a new set of rocker arms and rocker shafts out of the deal (new rockers are easy to get, and the work is fairly simple).
Can I ask where you got your rockers from?
Old Mar 26, 2022 | 06:34 PM
JohnZo's Avatar
Default New Rocker Arms and Shaft
No problem. Roverparts.com (aka Atlantic British).
I stuck with aluminum (steel cost more). Item 602153 (right hand), 602154 (left hand), 611659L rocker shaft. That was 4 years ago. Looks like AutohausAZ has them for less than I paid. Each side gets both kinds of rockers, right and left refers to the position of the bearing pads. You'll see they are offset differently when you look closely.
Old Mar 30, 2022 | 11:34 AM
gervin23's Avatar
But oddly, AB offers the whole rocker assembly (#611660) with no indication as to which side it's for.
Old Mar 30, 2022 | 12:02 PM
DiscoNewbe's Avatar
i had my cleaned by the machine shop and stupidly lost track of which side was which… I’m not sure it matters…
Old Mar 30, 2022 | 07:07 PM
JohnZo's Avatar
Default Two types of rockers, identical assemblies
To get the oil supply holes to line up, one rocker assembly has the notch towards the front, and the other towards the rear.
It isn't the assemblies that differ, it is the individual rocker arms. One type has the bearing pad towards the right, and the other towards the left. Both types are installed on both assemblies, one L and one R on each cylinder.
Old Mar 30, 2022 | 07:11 PM
Best4x4's Avatar
There is no L/R when it comes to Rocker Arm Assemblies. Yes to individual rocker arms, but when assembled you can mount them on bank 1/2.
Old May 3, 2022 | 05:16 PM
DiscoNewbe's Avatar
Eventually got to the bottom of all of this. My issue ended up being 2 brand new, but bad lifters. Also, some pushrods and rockers needed to be replaced ultimately.
Old Jul 5, 2022 | 01:01 PM
nukemedic's Avatar
8th Gear
Just chiming in that my 3.9 developed a worrisome tick and it also turned out to be a loose cup on one rocker arm. Just enough to allow it to spin in the arm, almost missed it even though I was specifically looking for loose cups, and surprised that it was enough to make that noise. But cleaned an old arm with good cup and installed and engine is quiet! This was on a pretty new shaft assembly from britpart which has the cups stamped into the arms in a pretty crude way...
me 2
Sep 10, 2020 01:16 PM
DiscoverVA
Aug 16, 2013 09:07 AM
torerickson
Jul 30, 2011 08:08 AM
XCELLER8
Nov 2, 2009 09:32 AM
XCELLER8
Sep 19, 2009 03:27 PM
