lifting engine and transmission out.
finally starting my 300tdi swap! anywho i've followed all the rave steps to get just the engine out and i can't get the engine to separate from the gearbox. where it says break engine or gearbox joint, it wont separate at all. i have a jack on the gearbox and a 2 ton lift with a leveler. any tips on that?
then i thought, if i take my arb bumper off i could get close enough to lift both out at the same time. i searched but i couldnt see how any of the others did it. so what's the best way to lift them both out at the same time?
thats kinda what i was thinking because i only pulled 5 bolts out, but i can feel 9 holes and cant feel or see anymore bolts. there were only 4 bolts holding the inspection plate on so i was kinda just thinking someone didnt put it back together very well.
i was thinking about putting the lift on the curb and push the truck close to the curb so i can get a few more inches to play with.
I just pulled both out together because, like you they didn't separate. There was one bolt I couldn't free(didn't know it was there until pulling both out). I used a engine hoist on the front of the motor, let the tranny fall down low and jacked it up and out.
It was scary, but worked. If I could do it over I would search for all of the 9/16 bolts and separate the tranny first.
I can give you a count if the bolts that separate them both tomorrow if need be, let me know.
15-17? rave says there is 8 on the bellhousing?
i think i am going to just try to take them both out. i need them both out anyways. so can i use the load leveler on the intake manifold bolts to pull them both out?
