Long crank, fuel problem
Old Apr 21, 2017 | 02:53 AM
El Duce's Avatar
Default Long crank, fuel problem
Hey everyone, a few weeks ago the fuel hose popped off my fuel pump and the truck sputtered out (because 6 years ago I thought a zip tie would be good enough) After that the rover has 35 psi at the fuel rail but it take about 10 seconds of cranking for the engine to start, if I put the key to position #2 and let the fuel pump prime the cranking is lessened to about 3 seconds of cranking, once I'm driving around if I turn off the engine and it sits for less then 30 mins it fires normally. Ideas?
Old Apr 21, 2017 | 06:24 AM
WaltNYC's Avatar
Not sure if these would solve it but the first things I'd check are the fuel filter and vac hose to the fuel pressure regulator. Get the 'easy' stuff out of the way first.
Old Apr 22, 2017 | 04:16 AM
El Duce's Avatar
Already replaced all the vacuum lines and fuel filter, it runs fine at wide open throttle without choking, it's as if air seeps into the fuel line while it is sitting while off
Old Apr 26, 2017 | 12:23 AM
El Duce's Avatar
Any ideas on what part of the truck I should troubleshoot next?
robson
Feb 22, 2018 05:42 PM
geek_IM
Jul 10, 2014 02:43 PM
JumPeR04
Apr 7, 2011 09:52 PM
97DiscoCincy
Mar 12, 2011 04:59 AM
audiS4S6
Apr 18, 2010 11:02 PM
