Looking for reverse "trigger" wire under dash for back up camera
Old Aug 15, 2022 | 01:07 PM
DiscoD's Avatar
7th Gear
Default Looking for reverse "trigger" wire under dash for back up camera
Hi all, first time poster here...just bought a 1996 disco 1 and am trying to install a new stereo with a backup camera. I'm looking for the reverse trigger wire so I can use it to let my head unit know when i'm in reverse. I believe it's the green with brown trace wire. It needs to be 0v when not in reverse and then 12v only when in reverse. The one I tapped into is in the driver's footwell but for some reason is giving 6v constantly when the power is on, regardless of if i''m in reverse or not. Is there a different wire or location I should have tapped into? Please see attached pic. Thanks!
Old Aug 16, 2022 | 12:11 AM
Icannap1's Avatar
On a D1 the rear-view mirror has 3 wires power, ground, and reverse you will need to add a 12-volt automotive relay since the wire is small but enough to power on a relay for your radio head unit backup input.
Old Aug 19, 2022 | 06:06 PM
DiscoD's Avatar
7th Gear
Thanks so much for your response! I just checked my mirror and the power wire is 11.75V (which is close enough to 12) but the reverse is only 10.5V. Any thoughts on that? I haven't had a chance yet to see if this will be enough to trigger my head unit to go into reverse mode yet but will try tomorrow.
Old Aug 19, 2022 | 08:33 PM
Icannap1's Avatar
It will work to trigger the radio, but it will not power a camera if you need it to power something just add a 12-volt automotive relay and you can run any aux or optional device just make sure to add a fuse if you run a relay.
Old Aug 19, 2022 | 08:42 PM
DiscoD's Avatar
7th Gear
I’m not totally sure how to add a relay but couldn’t I just use the stereo power to power the camera as well? It only needs power for the brief time I’m in revers. Thanks!
Old Aug 20, 2022 | 08:24 AM
aemnky606's Avatar
Wire relay as listed:
30- tap power from radio 12v
85- ground
86- tap reverse wire (trigger)
87- power to camera.
Old Aug 20, 2022 | 09:34 AM
DiscoD's Avatar
7th Gear
Thanks so much, I’ve never used one of these but seems like a great way to do it!
gunsanroses91
Aug 15, 2022 12:40 PM
Ivan Broodryk
Jul 30, 2020 10:39 AM
SoCalWiley
Jun 18, 2018 12:59 PM
roverwoody
Audio/Visual Electronics
Feb 11, 2014 01:18 PM
