Losing Coolant
Guys,
I am losing coolant at a pretty rapid pace, about 1/2 of the expansion tank a day.
I do not have white smoke or really any abnormal behaviors...just losing coolant...no puddles nothing...what gives?
There were some oily like substance in the expansion tank but my oil is not milky
And if leak is found to be in the rad, don't use stop leak except to get back home. You can pull rad in under 30 minutes, and take to indy shop, where they can rod out the calcium buildup, flush with hot acid, and solder up any small leaks. About $70 when I had it done. There is also a $232 replacement radiator available now, but it will be aluminum rather than the oem copper and brass. A new aluminum radiator will cool better than a sludged up old copper one. But the leak can be anywhere, hoses, water pump, various engine gaskets, even the expansion tank connection which is harder to see.
