Low Idle
Old Feb 19, 2016 | 03:06 PM
hrhoward's Avatar
Default Low Idle
Noticed that the vacuum hose to the fuel pressure regulator was off.
I have put about 150-225 miles on it this way. (Haven't had it that long)
Replaced it with new hose. Cleaned MAF and changed air filter. Prior to this the idle in gear was fine, 700-800ish. Since then, about a week and 100 miles, it has been low, 500-600ish and an occasional stall at a stop.
Clean the IAC and wait for a remapping on the ECU or something else?
Old Feb 19, 2016 | 06:12 PM
ihscouts's Avatar
Increase the idle speed with the throttle cable adjuster. Should be at 650 - 675.
Old Feb 19, 2016 | 11:18 PM
hrhoward's Avatar
Alright. I shall consult The Holy Book of Armaments. ..aka the RAVE.
It's a mechanical adjustment then?
Old Feb 20, 2016 | 11:02 AM
ihscouts's Avatar
Yes, mechanical, it's a thumb screw on the cable at the throttle. The throttle cable does stretch over time and since your not flooding the injectors at full pump pressure with the FPR now open it's probably a good time to take up some of the cables slack. You suggested checking the idle air solenoid which is a good decision too.
Old Feb 20, 2016 | 11:23 PM
hrhoward's Avatar
Thanks, I'll give it a shot.
sidinseattle
Jul 16, 2010 10:21 PM
krigsmakten
Sep 30, 2009 02:01 PM
jadedennill
Dec 10, 2008 07:11 PM
roverboy
Dec 3, 2008 08:05 PM
Classic89
Aug 10, 2007 08:58 PM
