Low Mass Air Flow MAF reading
Old Mar 10, 2012 | 04:12 PM
soundstream11's Avatar
8th Gear
Default Low Mass Air Flow MAF reading
I just bought a bluetooth OBD II and installed torque software. I noticed that my MAF reading is very low:
0.1 at idle
0.5 at mid throttle
1.2 at full throttle
It is a 1998 Discovery and the check engine light is on, but it is a P1193 and P1194 which is dealing with an O2 heater circuit. The car does run very well.
Do you think the MAF sensor is really reading that low, or do you think it is likely an issue with the software misinterpreting the reading?
Any thoughts or feedback would be greatly appreciated.
Old Mar 10, 2012 | 04:18 PM
According to my Ultra Gauge my MAF only reads like .72 while cruising and climbing a hill.
I should add I have no idea what the readings are supposed to be.
Old Mar 10, 2012 | 04:56 PM
Here's some pages on the MAF. In Roverspeak, it talks about Kg/hr on one chart and g/sec on the other, so some math conversion would be needed. But the chart indicates the volts would vary some with air flow, and codes will be thrown if out of range.
File Type: pdf
File Type: pdf
RedAustinIX
Dec 5, 2013 08:43 PM
zigzag3141
Oct 24, 2013 07:09 PM
Gavster
Apr 10, 2009 02:49 PM
akc
Nov 13, 2008 08:24 PM
flyinrover
Feb 24, 2006 12:04 PM
