Lucas ATF fix or PS leak stop
Old Oct 1, 2010 | 08:26 PM
bantham1's Avatar
Default Lucas ATF fix or PS leak stop
Which should you use for the D1? The Lucas ATF Fix or the PS leak stop. My PS gearbox is leaking from the bottom. ATF fix is a HUGE bottle and I would not probably need even half of it.
Old Oct 1, 2010 | 08:36 PM
discomedic4's Avatar
IMHO the Lucas won't work on a power steering leak. I tried it and no luck. The Lucas is good on some of the other leaks but not the PS. The ATF should help but I would personally go with White Shepard. You will have to order it (I got mine from Amazon). It is the best stop leak for the PS system. My leak was pretty large and now.....no more leak. Good luck!
Old Oct 1, 2010 | 08:45 PM
XCELLER8's Avatar
fyi...try Advance Auto.....they have it here locally
Old Oct 2, 2010 | 10:24 AM
Read the bottles of whatever you buy before using and then complaining. Lucas is for internal leak and valve issues, not external leaks.
If you want to stop an external p/s seal leak, go buy a bottle of White Sheperds p/s stop leak made by universal products, it works real well.
Old Oct 2, 2010 | 10:51 AM
I wasn't gripping Mike. You and I had this discussion when I had my leak and that is why I went with the White Shepard. I was just trying to make the same point you were but couldn't remember exactly what you had said about internal vs. external so that's why I said what I did. I was trying to steer him to the White Shepard.
Old Oct 2, 2010 | 10:58 AM
bantham1's Avatar
Advance Auto carries white shepard?
Old Oct 2, 2010 | 11:15 AM
XCELLER8's Avatar
YUP, $21.00 for a 8/12 oz. bottle
Old Oct 2, 2010 | 06:41 PM
Double check, they usually have Blue Devil and the generic oil stop leak but not the p/s leak, got to buy it on line.
Old Oct 2, 2010 | 10:05 PM
dansgt's Avatar
yea lucas ps doesn't really stop leaks, but it's great for quieting a whiny pump.
COBRA
May 27, 2013 02:17 PM
CapeRover
May 3, 2013 04:35 PM
mx468
Nov 28, 2012 09:00 PM
lipadj46
Jul 8, 2009 07:41 PM
