lucas maf
Old Jan 21, 2013 | 06:17 PM
AK_Disco_Driver's Avatar
Default lucas maf
so i planned to clean the maf today, its a lucas pn err5595a. Came out easy enough and the screen was easy to remove, my question is that most of the videos i see are people pulling the sensor out of the housing and spraying it. mine has 4 rivets so do i just spray a few bursts down the plastic hole behind the screen and do i make sure it clean the whole bore or just the little wires down there. i dont want to make an expensive mistake so im asking first
Old Jan 21, 2013 | 08:01 PM
anyone have any idea I've searched multiple threads.
Old Jan 21, 2013 | 08:06 PM
If you use made-for-MAF cleaning spray, and you do this when the item is cold, not plugged in or switched on, because a tiny spot inside is heated to 350F + ambient. So cold spray + that equals snap. I took the screen off of mine to clean, but it is from a 97.
Old Jan 21, 2013 | 08:17 PM
i gues what i am asking here is that after the screen is removed do i just spray it down the hole?
Old Jan 21, 2013 | 08:22 PM
yep, and the screen.
Old Jan 21, 2013 | 08:32 PM
thank you
Old Jan 21, 2013 | 09:47 PM
Dont remove the screen, just spray the whole damn thing, let it dry and put it back.
Old Jan 21, 2013 | 11:48 PM
actually did remove the screen. cleaned it and she seems to be running smoother, felt a lot less sluggish off the start.
malmberg
Aug 31, 2009 06:34 PM
PITTDISCO
Feb 22, 2008 09:51 PM
jdelp
Aug 6, 2007 01:59 PM
morfa
Feb 13, 2007 07:14 PM
Brad S1
Sep 5, 2006 05:44 PM
