Lucky8 Body Lift
Old Jan 30, 2011 | 12:01 PM
thehun's Avatar
Default Lucky8 Body Lift
Anyone used one before? How do the bumpers look, do they include bumper relocation brackets?
Seems to be a good idea to fit 32-33" tires with a 2" suspension lift without too much investment
Thanks guys
Old Jan 30, 2011 | 03:42 PM
Spencerfitch's Avatar
Funny I just called them for one. They weren't sure if they had them and they were only 1.25" and about 125. I'm not sure of what it came with but it isn't come with steering extension (not needed anyways) I'm not sure if it came with body tie rod extensions or radiator bracket.
I wanted two inches anyways for me 33.5" tires so I ordered 10 2x2" poly blocks off amazon and 10 6" grade 8 bolts for 60$ steering extension SHOULDN'T be needed for 2" radiator bracket is simple. Drill a hole 2" lower from existing! As for body tie rod haven't figured thy out yet. But I'm saving slot of money
Old Jan 30, 2011 | 04:36 PM
antichrist's Avatar
For a 2" body lift done right and safely you need the steering extension. The RoverTym kit comes with it, as does the DAP kit I believe.
Also you want metal blocks for the extension, not rubber or poly. If it's not rigid they will allow too much movement in the body.
Old Jan 31, 2011 | 02:51 AM
Poly is more thn fine. Rovertym won't ship for 3 weeks and lucky doesn't have them. Steering extension is safer!
Old Jan 31, 2011 | 09:53 AM
thehun's Avatar
they dont make it anymore...freakin great
Old Jan 31, 2011 | 10:25 AM
antichrist's Avatar
Check with DAP.
Also here's one.
http://cgi.ebay.co.uk/Body-Lift-kit-...item5191c2e54e
Although the ebay one doesn't appear to include the steering extension, though that wouldn't be difficult to make.
It has nylon spacers for the body floor pan which is ok, but has aluminum spacers for the main supports which is best.
I've had a RTE kit for over 7 years with no problems at all, including rough off-roading and carrying heavy loads.
Old Jan 31, 2011 | 11:28 AM
thehun's Avatar
my question is for you body lift guys is two things...one how does the front and rear bumpers look after body lift..i used to have a silverado and when you body lift you had to get bumper relocation kits...second..can it be done by one person?
Old Jan 31, 2011 | 02:26 PM
Look around for pictures. Umpire relocation is super easy just Berbers right bracket which almost anybody can find or make you need a drill a measuring tape and a peice of metal.
It can be done by one person though it's a bit tricky. You need something to hold the nut while you turn the bolt or vice versa I have done it before a racket will spin and eventually find somethihg to lever against.
Old Jan 31, 2011 | 04:04 PM
A good 2" lift will give you all the room you need without doing a body lift.
Old Jan 31, 2011 | 08:25 PM
antichrist's Avatar
All the Disco body mount bolt heads and nuts can be reached at the same time.
shady milkman
Apr 1, 2021 09:57 PM
TheWhiteRover
Sep 12, 2014 08:57 PM
Fivespddisco
Off Topic
Dec 5, 2009 09:56 PM
Fivespddisco
Oct 10, 2009 01:52 PM
Fivespddisco
Jun 20, 2009 10:32 AM
