Lug Nut Cap Removal Tool
Old Apr 19, 2012 | 10:16 AM
jeff spahn's Avatar
Default Lug Nut Cap Removal Tool
I have designed a lug nut cap removal tool. I will be happy to lend it out to anyone as long as they return it when done.
You merely put the lug nut in a socket, put a small socket on the end of the pin (you provide this) to keep from pushing the pin through the end of the cap and also provide a swivel.
Hold the socket containing the lug nut and drive bolt with the pin into the lug nut with an impact gun. Takes the cap off in about 2 seconds.
PM me if you want to borrow it. I'll ship it to you if you promise to send it back.
Old Apr 19, 2012 | 10:42 AM
wheelgarage's Avatar
That thing looks just like the bolt for a chain breaker....
Old Apr 19, 2012 | 10:48 AM
slanginsanjuan's Avatar
dont need it but thanks jeff.
hope you get some good karma.
Old Apr 19, 2012 | 10:49 AM
jeff spahn's Avatar
Nope, had it custom made at a machine shop.
Old Apr 19, 2012 | 11:59 AM
Jake1996D1's Avatar
Why remove the cap? Then they look funny
I dont get how everybody screws these things up I had them for a year with no problem before I switched to steel rims and lugs..
It's not rocket surgery...
Old Apr 19, 2012 | 12:06 PM
Chris-bob's Avatar
It's the tire shops/roadside assistance that screw them up. Then when the new guy gets the Disco, and starts DIY repairs, he/she finds buggered up lug nut caps. Easiest fix is to remove caps and wait till the funds are available for new ones if you want new ones.
Old Apr 19, 2012 | 12:25 PM
jeff spahn's Avatar
Originally Posted by Chris-bob
It's the tire shops/roadside assistance that screw them up. Then when the new guy gets the Disco, and starts DIY repairs, he/she finds buggered up lug nut caps. . . snip
Exactly.
Old Apr 19, 2012 | 12:41 PM
Danny Lee 97 Disco's Avatar
That is why I got the solid capless ones like were used on a RRC.
Old Apr 19, 2012 | 12:49 PM
Jake1996D1's Avatar
Guess I got lucky? If you go to a tire shop that doesnt know how to take off and put on a lug nut you likely have bigger issues.
You can get the from most parts guys cheap. Hell I actually still have all of mine if anybody needs some
Old Apr 19, 2012 | 01:18 PM
fishEH's Avatar
I worked on a D1 last night that had some really boogered nuts. The 27mm wasn't even close. Nor.was the 1-1/16". Had to use a 1-1/8" socket, which was just a touch sloppy. Didn't want to use my impact with them being that bad. I forgot how much removing lugs by hand sucked.
