MAF question for a friend
Maybe a silly question but how does he know it is any good? was it tested? was it cleaned?
It should say Hitachi or Lucas 5 AM on the top of the MAF, right next to the elec. plug.
Clean the MAF (when it is cold) by lightly spraying MAF specific cleaner into the small hole on the side of the primary flow chamber. Don't poke the tube from the cleaner can into the hole or you could damage the two delicate wires in there. You're just cleaning a small wire... not much needed. Also, it is best to align the MAF vertically so the cleaner and residue can run out the bottom of the chamber. Let it dry completely before plugging it back in.
The test is fairly easy but whenever one works on these they need to be delicate. With a multimeter and some light breath do the following to see if it is even good....Ignition should be on but engine NOT running. Connect the meter between the the ground (red black wire) and air flow sensor output (blue green wire)... now lightly blow into the sensor hole... the voltage should rise quickly with your breath if it is good. If it is good, reconnect the air filter box and start the engine. Using the same wires to test voltage... you should see about 1.7 volts at idle and just above 4 volts under high rpm's.
Hope this helps... good luck. Let me know if it is bad.... I have an extra few layin' around.
JohnZo (07-23-2023)
texmbr
01-24-2011 07:57 PM
strictlyb
01-28-2010 11:10 PM
