Making progress on my 98 Disco!
Old Apr 24, 2011 | 08:58 PM
  #21
We need to be 100% clear.
Do you need the power steering pump? Which is what has the pulley on it.
1994-1999 Discovery I Power Steering Pump
Or do you need the steering box? Which is what turns the wheels.
1994-1999 Discovery I Steering Gear Box
The pump bolts to the engine, the steering box bolts to the frame.
Old Apr 24, 2011 | 09:49 PM
  #22
ShadowMerchantBC's Avatar
Banned
I need the power steering Box. Based off the diagram you Spike sent me. The part that leaks is located on the frame.
Old Apr 25, 2011 | 08:55 AM
  #23
turf63's Avatar
Yeah. That was my fault for the confusion from jump street. You described the box and I called it the pump by accident. Sorry to mix everyone up. Def the box. Let me know if the stop leak works. Mine is a little swept too
Old Apr 25, 2011 | 01:33 PM
  #24
a2tz's Avatar
I had the same problem. Tried a few different brands of stop leak, but I actually did get mine to stop leaking after the 3rd attempt. Best of luck to ya!
Old Apr 25, 2011 | 01:57 PM
  #25
tweakrover's Avatar
The power steering uses atf not power steering fluid, if you used power steering fluid its thinner and may promote leaks. Just making sure you know.
Old Apr 25, 2011 | 05:45 PM
  #26
Banned
Hmm generally speaking how bad was the leak from the steering box for everyone else? What Im wondering is weather or not stop leak will be able to hold back a moderate fluidly leak? Is it capable? Secondly I have been using poswer steering fluid :s Have briefly looked around for ATF with no luck. Where is a good place to get it?
  #27
Banned
And what does ATF stand for?
Old Apr 25, 2011 | 05:57 PM
  #28
philander's Avatar
Automatic Transmission Fuid.
Old Apr 25, 2011 | 06:08 PM
  #29
Banned
Auto Trans for the power steering fluid? Wierd. Rover tech keeps getting stranger and stranger! But I love it.
Old Apr 25, 2011 | 07:11 PM
  #30
Banned
Will ANY brand of ATF work for either my transmission or my power steering? Or should it be "AMSOIL ATF"?
