Manually lower power seats?
All of the above work, and the seat motors have a drive cable like an old school speedometer cable . If you can't find a ragged out seat at the junk yard (to rob motors from), you can use a battery drill and spin that drive cable to a desired spot. Certainly check all the electrical first.
on
If any switch works well, you can swap it into the driver's seat and try that.
Replacement switches are expensive if you buy new on the other hand a few bucks at a pick & pay or reasonable from recyclers.
I little contact cleaner spray can also work wonders for a few bucks. Even PB Blaster, WD40 or similar will work. CRC contact spray evaporates and leaves no residue.
goatman
01-12-2013 10:08 AM
booper169
11-09-2010 09:10 AM
