mil light
Old Jul 2, 2023 | 11:04 AM
rjlsierra's Avatar
Default mil light
97 D1 113;500mi, i've owned this truck for 25yrs never had the mil light go on,recently have had health issues and haven't been able to drive,my horn went off so i pulled the fuse, after charging when i go to lock and turn alarm on the light goes on,is it possible by pulling the fuse that is why it goes on and if i lock and light blinks is it ok to leave so at least it will be safe
Old Jul 2, 2023 | 03:51 PM
Best4x4's Avatar
We're talking the Maintenance Required Light correct and not the Check Engine Light correct? If so you can simply remove the brown relay behind the passenger footwell kick panel. It's only there to make LR Dealers $$$. Remove it and forget about it.
Old Jul 2, 2023 | 05:09 PM
rjlsierra's Avatar
it's the brown light problem is when on you can't start car,in this car i was always told multifunction indicator light,if i lock truck it blinks do you think it's ok to leave blinking since vehicle would be locked and do you think that by removing the horn fuse is the reason
Old Jul 5, 2023 | 01:51 PM
jastutte's Avatar
are you sure all the doors are locking when you lock the D1?
i had the same issue years ago on my '96 Discovery and it was a lazy lock actuator that was not locking the rear, driver's side door. this would set off the alarm every time. horn honking and alarm light blinking.
Old Jul 6, 2023 | 10:41 AM
rjlsierra's Avatar
the car is unlocked and i can't open with keys after charging it started right up noe i can;t lock or unlock know how i can get i get in
Guy McFadden
Discovery Sport
Nov 3, 2019 07:30 AM
philh5197
Jul 17, 2011 02:32 PM
hillbilly hangover
May 24, 2010 05:12 PM
Biggs!
Apr 25, 2010 10:41 PM
2000 DII
Apr 11, 2008 12:58 PM
