New to the Forum
Old Apr 10, 2008 | 06:12 AM
2000 DII's Avatar
Default New to the Forum
Hello,
I have been reading this forum, but just registered today. Love it!
I saw someonetouched on seat heaters for the 2000 Discovery II. What is the test light they were referring to for checking the fuses andwhat else could cause my seat heater not to work, other than the fuse? Any suggestions would be greatly appreciated!
Old Apr 10, 2008 | 03:45 PM
Default RE: New to the Forum
The best way to describe a test light is this-it looks like a screw driver but the tip is pointed like a center punch, in the handle is a light bulb and sticking out of the top of the handle is a wire with a alligator clip.
You take the clip and attach it to a ground and stick the pointed end into the socket that you need to check, if it is good the light will light up, if not, well it wont.
You can get one at almost any store with a hardware dept, pretty cheap too.
Old Apr 11, 2008 | 06:29 AM
Landzu's Avatar
On new fuses you can take the test light and check the fuses with out pulling them, on top of the fuses there is a contact point for each side with out pulling the fuse check one side get the light on check the other side no light thats the bad fuse.
Old Apr 11, 2008 | 12:58 PM
2000 DII's Avatar
O.k. Great!I thoughtmaybe it was a "special" test light. I have that tester already, so I'll give it a shot and see what I come up with.I appreciat it!
MuddMouth
Sep 30, 2010 10:30 PM
Cosmic88
Jul 15, 2010 07:32 PM
m4ver1ck
Jul 22, 2009 08:03 PM
ctcnewton
Feb 18, 2006 12:32 AM
BFREE
Apr 25, 2005 01:32 AM
