Misfiring issue...
This is driving me nuts! If I don't drive her a couple days or we have rain with a lot if humidity (which here if Florida is every day during the summer) she will misfire for about 10 minutes or so until she gets hot and just like that it stops. The ultra gauge is showing codes 1313 and 1314, Misfire bank a and b duh! I duct taped around cover of ECM but that wouldn't stop condensation build up. I was thinking of spraying everything done with soft seal, it's a moisture inhibitor used a lot in the marine field. Any ideas would be greatly appreciated...
Have you tried corrosion block? I live in Pensacola. (the humidity capital of the world) I got this idea from a marine application here. I had a boat with twin volvo's that I had a miserable time with electrical contacts staying clean. I sprayed this on all of the Disco engine parts that were corroded. Pretty much eats the corrosion then seals it.
Nope, haven't tried that, soft seal is oretty much the same thing except it is for use before corrosion sets in. Probably get a can if that to have in hand though, I'm sure corrosion is lurking in there some where...
Did you pull them or spray in place?
Just more than misfire, I would disconnect the exhaust from manifolds cold and start the truck and see if you still miss. You may have bad/plugged cats. This code is often thrown by poor operation of the O2 sensors down stream from AICV and fuel temp sensor. Remove and soak O2 sensors over night in brake parts cleaner.
Have you had transmission removed recently? you could have bent tines on your flywheel from removal of the 4 bolts holding the torque converter causing intermittent pickup from the crank sensor located lower driver side of the block. just a thought!
