Misfiring and knocking noise
Old Jul 2, 2012 | 09:20 PM
coastroamer's Avatar
8th Gear
Installed new rod and main bearings which raised the oil pressure and made it run a little bit quieter, but still the noise is there. Cylinder #3 has no compression. Is there a way that the rings might of burned out on just that single piston? How can this be fixed?
Old Jul 2, 2012 | 09:43 PM
EricTyrrell's Avatar
To fix a broken ring requires disassembling the engine, replacing the ring, and reassembling the engine while replacing the required gaskets. It may be a stuck valve though and there are likely more worn out components so it may need a complete rebuild.
Old Jul 2, 2012 | 10:10 PM
8th Gear
How can I further check if its bad rings? Is it possible to replace the rings without honing the cylinder? What I mean is can I just pull the oil pan and pull out the piston from underneath?
I know its not my valve because I had them cleaned and I also removed the valve cover while spinning the engine to see if the lifters were stuck and everything seemed fine.
Old Jul 2, 2012 | 10:21 PM
8th Gear
Possible bad valve seating? but it wont make that loud of a noise, right?
Old Jul 3, 2012 | 12:04 AM
Looking at my engine rebuild pics I suppose it'd be possible to remove a connecting rod cap and push it and the piston out the top. First, with the heads off, I'd examine the valves further of course.
Old Jul 3, 2012 | 03:23 AM
8th Gear
I just did a dry and wet compression and there was no psi what so ever I even plugged the hole with my thumb and didn't feel anything compared to the other 7 which averaged to about 90-100psi.
Old Jul 3, 2012 | 09:48 AM
Was the engine warm for the compression test? Even 90-100 psi is very low.
grussell
Dec 15, 2008 10:03 AM
tobob1
Nov 27, 2006 02:11 AM
mr.47
Sep 25, 2006 09:01 PM
tobob1
Sep 11, 2006 09:14 AM
disco1
Mar 3, 2006 10:29 AM
