MJ 98 A/C fans
I would recommend checking if the fans have power with the a/c switch on and truck running. If they do, motors are probably the issue.. If not, it could be a lot of other issues. Im currently battling this myself.
Mr. George,
oilspotLR is right, those fans should come on as soon as AC is turned on. Fuse 3 under hood, and relay K109 on bracket with other relays beside SWMBO right foot, assumes your normal place of pilot-in-command. Under right side fascia. Both fans need to work. Also come on above 212F, and if very hot under hood and truck is turned off.
Mr. George,
