Mk 1 Disco Heater removal
Old Sep 3, 2010 | 12:19 AM
Stormin's Avatar
Default Mk 1 Disco Heater removal
Hi,
Haynes manual is about as much good as a chocolate fireguard.
Looking for the easiest way to replace heater fan (1992)
Old Sep 3, 2010 | 07:00 AM
kenk's Avatar
80 HEATING AND VENTILATION
REPAIR
BLOWER MOTOR UNIT - HEATER AND AIR
CONDITIONING
Service repair no - 80.20.17
Service repair no - 82.25.54.
Remove
1.
Move seats to rear most position.
2. Disconnect battery negative lead.
3. Remove fascia panel assembly. See CHASSIS
AND BODY, Repair, Dash Panel Assembly
4.
Remove 2 nuts securing lower brackets to
toeboard.
5. Manoeuvre blower unit from heater unit and
remove.
Refit
6.
Reverse removal procedure. Ensure seal
between blower and heater unit is tight.
BLOWER MOTOR
Service repair no - 82.25.33.
Remove
1.
Remove blower motor unit. See Blower Motor
Unit - Heater and Air Conditioning
2.
Release wiring harness retaining clip.
3. Remove 3 screws securing casing.
4. Remove blower motor assembly.
I don't know if this is any better than the one you have. Looks like it's pretty simple, but I couldn't get the pic's that goes with it.
On the glove box side,there is a black cardboard trim piece in the footwell, sitting horizontally under the glovebox. If you remove that, the blower motor is behind that. Looks to be a few bolts and/or screws and it's out.
Old Sep 3, 2010 | 07:02 AM
kenk's Avatar
What is your's doing(or not doing)? Not working?
SuperSport
Dec 6, 2019 01:18 PM
ls1morethanyou
Jan 12, 2017 10:21 AM
wick_60010
Oct 4, 2009 06:35 PM
stanigu
Jan 18, 2007 04:25 PM
pclloyd
Jun 17, 2006 08:13 PM
