Moving cruise control module
#22
first off thanks guys for the help.
now the next chapter in the cruise control saga. repeated the diagnostic procedure again just a bit ago. everything checked out fine but still no working cruise. i have noticed some relay clicks and am wondering if anyone out there with a working cruise would be willing to check something for me. or if someone knows the answer please chime in.
sitting in the truck, ignition on, trans in park, push the cruise button and i hear a relay click. push shifter button - relay click. shift into reverse or drive - relay click.
in truck ignition on, shift into a drive gear, all the appropriate shifting clicks. with trans in a drive gear push the cruise button -NO relay click. Is that normal?
Could someone with a working cruise sit in their truck with it in gear and then push the cruise button and see if they hear a click?
along those lines, im having a hard time isolating that cruise relay. can anyone help me narrow down the search?
i know im asking a lot for a pretty non-critical system so thanks in advance to anyone who is willing to help.
Adam
Adam
#23
Just noticed your question about the vac. hose (white or black fitting?). Did you ever get confirmation? I have a 96 Disco. 1 and the hose was not connected when I purchased it. Thanks.
Gil
#24
#25
on
The Discovery grounds can be a cause of lots of problems. Also there are a lot of splices internal to the wire harnesses. I do not know if this specific circuit has such, but if you have checked everything else in the loop, you may need to physically check the wiring for any intermittent connections.
#27
well, after fiddling with it and probably wasting a few bucks on a used cruise ecu i got it working. it seems it was a grounding issue. i removed that bare braided ground strap thats under the hood by the bottom of the windshield, cleaned up the connections and put it all back together and magically it all works.
i can only guess that everything was working during the static tests because i was using a convenient ground in the area i was probing.
anyway i hope it holds and i hope this can help someone else with a similar problem.
Adam
Adam
Evan5291
11-21-2017 07:59 AM
Mecevans
08-09-2015 02:30 PM
southfloridadiscoII
06-28-2009 11:03 PM
The Capstone
05-11-2006 12:57 AM
