Mug flaps replace
Old May 18, 2013 | 04:34 PM
olywa's Avatar
Default Mug flaps replace
I want to replace my mud flaps but not sure how to remove the bolt? It doesn't seemed threaded more like a riviot. Any advice?
Old May 18, 2013 | 05:24 PM
TOM R's Avatar
guess it depends on the type of flap think there are 2 or 3 types at least 2
Old May 18, 2013 | 05:55 PM
olywa's Avatar
They looks like rviots.
Old May 18, 2013 | 06:26 PM
TOM R's Avatar
do you have molded running board, wheel well mud flaps or the standard ones that hang under the vehicle?
Old May 19, 2013 | 02:17 PM
olywa's Avatar
The standard mudflaps that hang under them. I have a pic can't seem to attach it.
Old May 19, 2013 | 03:24 PM
TOM R's Avatar
i think they are pop riveted to the brackets, the other type are bolted with hex key bolts
Old May 19, 2013 | 04:56 PM
coors's Avatar
My '01 were riveted. But I believe they're rivoted to a frame that screws into the molding.
Check out Rovers North for more details.
Old May 19, 2013 | 08:03 PM
NabisOne's Avatar
Mine were riveted on and when I removed my side steps they looked weird so I drilled out the rivets and made new flaps then used stainless bolts and nuts in the old rivet holes.
Old May 19, 2013 | 10:38 PM
olywa's Avatar
The rivets. I can drill out?
Old May 20, 2013 | 10:06 AM
WaltNYC's Avatar
I used a cutting wheel to get mine off. Replaced with nut/bolt.
