My D1 is Overheating @ idle... Crazy, I know
Old Jul 6, 2020 | 06:52 PM
DiscoNewbe's Avatar
Default My D1 is Overheating @ idle... Crazy, I know
Hi everyone,
It seems my D1 maintains good running temps so long as I don’t let it idle in traffic. Once that happens temps average 205°-207° F (OBD Fusion App) and the temps never seem to be able to get back down to where they should be until I shut the engine off. If I idle in traffic for an extended period of time my engine temp goes up to 212°F.
Another point of interest is that while hauling a full 5’x8’ Uhaul trailer for a 10 hour drive engine temps stayed below 212°F except when going up extended up hill gradients on the freeway, but this was easily resolved by running the heat in the cab, might this suggest a partially clogged radiator?
What works:
1. 2 brand new auxiliary fan motors
2. A working auxiliary fan switch that engages when engine temps exceed 212°F and stays on for ten minutes after shutoff (auxiliary fans work when A/C is on also)
3. Brand new fan clutch (blowing air in the proper direction)
4. Proper amount of coolant present in the reservoir
5. Functioning reservoir cap - 10 min after engine shutoff you can feel the pressure on the cap and 30 min after shutoff there is a pressure hiss if you unscrew the cap
6. Brand new heater core
What’s old:
1. Thermostat
2. Radiator
3. ....head gasket... (my OBD fusion app shows no missfire codes, there is no white smoke coming out of the tail pipe, last oil change showed a black oil w/ no milky consistency)
Does anyone have any idea? My current opinion is that I may need to recore my radiator, but this is a new problem for me.
Thanks
Old Jul 6, 2020 | 07:01 PM
Radiator or water pump would be my first thought. Thermostat is easy to check
Old Jul 6, 2020 | 07:10 PM
DiscoNewbe's Avatar
any checks you can think of to rule out the water pump? I would be seeing coolant on the ground right?
Old Jul 6, 2020 | 09:54 PM
dos531's Avatar
What is the outside temp? Those numbers seem totally normal to me.
Old Jul 7, 2020 | 11:27 AM
WaltNYC's Avatar
Having experienced very similar temps, I'd guess your radiator needs a re-core.
Old Jul 7, 2020 | 12:10 PM
DiscoNewbe's Avatar
It has been hot with temperatures above 90°F. My main concern is how easily my temp gauge climbs when idling in traffic, I don’t feel like it should be doing that and it should be able to maintain a good operating temp while idling especially now that all three fans are new and functional.
Even on a hot day at startup my temps seem to rise to 187°F and then it’s a slow march up to 205°F which may be an indication of a radiator problem.
Also, I can’t seem to find in the electric manual or the workshop manual what the normal operating temperature for the GEMS V8i engine is so I don’t have any way of knowing if the operating temp is correct.
Old Jul 8, 2020 | 01:17 PM
WaltNYC's Avatar
Normal operating temps... stock thermostat is 190F (88C). e-fans energized at 212F. I suppose that is the intended range.
Old Jul 8, 2020 | 01:24 PM
DiscoNewbe's Avatar
Hmm, that’s some solid logic
Discox7
Aug 2, 2019 09:08 PM
thatbaldguy
Nov 26, 2016 10:27 PM
WaltNYC
Aug 25, 2015 08:42 AM
pgk
Aug 31, 2013 05:00 PM
Smith CH
May 28, 2013 07:09 PM
