My next problem/ Lock washer
Old Jan 6, 2013 | 10:12 AM
fishEH's Avatar
Originally Posted by antichrist
I have to say, this thread is making less and less sense.
Just to be clear:
Ok, good. I thought I was the only one.
Old Jan 6, 2013 | 12:34 PM
Bkreutz's Avatar
You're not alone, I just can't think of a response
Old Jan 6, 2013 | 01:15 PM
ihscouts's Avatar
That makes four of us......
I'll say that by looking at the grease it looks like it hasn't had any attention for awhile.
Something is sticking out from under the nut threads (top of stub and right of center) and probably jamming the nut solid...hence needing a socket to crank over it. I still think it's gonna be time for a new stub because the threads will now be crossed or wiped out.
I can't help shaking my head at this.......
Old Jan 7, 2013 | 08:43 AM
WaltNYC's Avatar
to the original question.....first you need to take the nut off. IIRC it is a 52mm nut but many use channel locks or even tap on a flat side of the nut with a drift until it begins to spin a bit. The bent washer is BEHIND that nut. It looks as though you may have damaged some of the threads so proceed with care.
Old Jan 7, 2013 | 10:09 AM
DiscoJag's Avatar
Once the locking washer was bent back, mine were finger tight.
ewatk
Nov 1, 2011 03:21 PM
NiteTrain
Sep 13, 2010 08:44 PM
krazzz
Jan 15, 2010 07:17 AM
dherbs85
Appearance & Camping Set Ups
Nov 17, 2005 03:30 PM
