front wiper and washer problem, driving me crazy
Old Oct 30, 2011 | 02:54 PM
ewatk's Avatar
3rd Gear
Default front wiper and washer problem, driving me crazy
At some point my wipers stopped working correctly, they dont park in the down position and it seems they only work in one speed, I assume this is either the stalk or the park switch in the motor. However my windshield washers do not work either. it seems they both went bad at the same time, but I cant be sure. The washer pump works and the hoses are clear (I connected the rear switch to the front pump and now I can wash my windshield) could it all be a problem in the wiper switch or do I just have 2 problems that happened at the same time?
Old Oct 30, 2011 | 05:26 PM
This sounds more like a switch problem to me, the switches are cheaper and easier to replace than the wiper motor.
Old Oct 30, 2011 | 09:05 PM
Yep, the park switch gets it's voltage feed from the stalk switch, so replacing the switch will probably fix all 3 problems.
Old Nov 1, 2011 | 02:24 PM
SharriTX's Avatar
Hate to be such a ditz - but where are the switches located? I know you mentioned above, but exactly where are they? I need to get my Disco II inspected and my front wipers aren't working...expensive on the service area if it is the motor. Thanks!
Old Nov 1, 2011 | 03:12 PM
The switch we are talking about is the stalk that pokes out of the steering column, you twist and move it to select various functions for the wipers. You replace the unit.
Old Nov 1, 2011 | 03:21 PM
see this link for RAVE page on replacement, and there are work arounds that make it somewhat easier if you decide to DIY
https://landroverforums.com/forum/at...per-switch-pdf
jacekk
Oct 7, 2013 12:25 PM
Boots63
May 5, 2011 04:29 AM
krazzz
Jan 15, 2010 07:17 AM
sloppyjoe
Dec 2, 2008 02:22 PM
Bill E
Mar 10, 2008 01:03 PM
