Mystery seal in my swivel ball kit
Old Oct 9, 2010 | 11:53 PM
geek_IM's Avatar
I'm not disputing you, just curious - this is off the AB website:
Hub Oil Seal With ABS - Rear
Our Price: $5.95
Item: FTC5268
In Stock: Yes!
Fits:
Discovery I | '94 - '99
Range Rover Classic | '87 - '95
Defender 90 | '94 - '97
Defender 110 | '93
Where is yours from, and does it have the metal part stuck in the back?
Old Oct 10, 2010 | 12:23 AM
NiteTrain's Avatar
I got mine from fap99.com and yeah it has metal in it and you can see the metal from the back
Old Oct 10, 2010 | 08:40 AM
kenk's Avatar
I'm sure you already checked, but it's not the seal that goes in the end of the swivel ball itself, where the axle passes through?
Old Oct 10, 2010 | 10:54 AM
lordmorpheus's Avatar
https://docs.google.com/fileview?id=...thkey=CI6ayZ0G
Do you see the mystery seal anywhere in this exploded diagram?
Old Oct 10, 2010 | 12:28 PM
geek_IM's Avatar
arrrgghh. Right seal, wrong description on AB site.
Unfortunately, it IS the stub axle seal. I replaced it with the same that was in there, and I imagine it was wrong to begin with. That would go a long way to explaining why it was leaking so badly.
I'm going to be REALLY good at rehabbing stub axles. grrr..where's my grinder...
Old Oct 10, 2010 | 02:23 PM
Danny Lee 97 Disco's Avatar
That's exactly why I study all the documentation possible before I start a repair and have it handy during as well.
I have never worked on anything remotely similar to the mechanical beasts so I want to get it clear as possible. But at least you caught it early.
Old Oct 10, 2010 | 07:21 PM
geek_IM's Avatar
Ha! I put it in the freezer for two hours, then quick heated the thrust ring with a butane pencil flame and it popped right off with slip joint pliers. Three cheers for neverseez.
Then I beat the seal out with a hammer and a piece of pvc pipe from the backside and the bearing popped out too, unscathed. So all in all I'm down $5 for the wrong seal, not too bad.
Driver's side is all buttoned up, and if my parts had come it would have been done. Learned a ton about the vehicle, tho.
Lol did you know that the big swivel ball seal retaining plate has a front and back? Well, I didn't, but I sure do now.
Shiftonthefly1
Jul 7, 2013 12:56 PM
coldstart
Mar 25, 2012 10:03 AM
bmxermike
Apr 4, 2011 02:10 PM
studlee
Aug 8, 2006 10:29 PM
btp226
Jul 12, 2006 05:34 PM
