Name That Part
Old Oct 25, 2016 | 09:34 PM
colemtd's Avatar
Originally Posted by stillruns
you''ll need to buy a really tiny comode from home depot, hook it up to your breakline, and then flush the comode. Works everytime.
lol..
Old Oct 25, 2016 | 09:40 PM
aemnky606's Avatar
You will need 3pints of DOT 4 brake fluid. A tube to fit over bleed screw and a jug to catch old fluid. I believe a 10 mm box wrench. And a helper that can push the brake.
During this process you will need to keep the master cylinder reservoir full of fluid at all times. You will start at rear passenger wheel put the tube over the bleed screw and open it up pump the brake pedal until you see clear fluid coming out. move to drivers rear wheel and do the same. passenger front and last driver side.
Old Oct 26, 2016 | 02:26 PM
colemtd's Avatar
Thanks, might be a silly question but I'll go for it anyway LOL.. Each wheel that you bleed will decrease the fluid in the reservoir, right? So if you keep the reservoir full won't it mix with the old fluid?
Old Oct 26, 2016 | 02:51 PM
WaltNYC's Avatar
That is actually an excellent question.... yes, to a limited extent it will.
But what you are trying to do is push the old stuff out ahead of the new stuff.
Also, there is a preferred order in which you should bleed the brakes beginning with that wheel farthest away from the ABS block. On your truck that would be
1. rear passenger
2. rear driver
3. front passenger
4. front driver
(Though I've read some claim there is some pipe routing which makes this order debatable.)
Old Oct 26, 2016 | 03:07 PM
colemtd's Avatar
1. rear passenger
2. rear driver
3. front passenger
4. front driver
OK, thanks. so I bleed one wheel, and then check the reservoir to see if it needs to be topped off, and then do that same thing with the other 3 wheels?
And the reason I do that is to stop air from getting in the brake lines?
Old Oct 26, 2016 | 05:34 PM
OverRover's Avatar
Yes. If you let the fluid run low and you draw air into the master cylinder you will be bleeding this for day. Before you start clean the bleed screws/valves with a small wire brush( an old toothbrush will work). Then give the threads a shot of penetrating oil ( PB Blaster, etc ).
Old Oct 26, 2016 | 06:19 PM
colemtd's Avatar
Thanks!
Old Oct 26, 2016 | 08:20 PM
ihscouts's Avatar
Um, these guys forgot to mention that when you bleed brakes you start with the one furthest from the reservoir - which means..... you start with the passenger side rear, drivers side rear, passenger side front and finally the drivers side front.
Never mind, they mentioned it....... I got all excited.
Old Oct 26, 2016 | 09:25 PM
colemtd's Avatar
HA HA.. Thanks!
Old Oct 26, 2016 | 09:40 PM
ihscouts's Avatar
One thing I do recommend is having someone to help either pump the brakes or do the bleeding. When pumping the brake pedal it's important to hold the pedal down while the other person closes the bleed screw, that way no air gets sucked back in.
If someone mentioned that then I got excited twice...... which is one time less than usual, still ahead of the game........
sforb
Apr 15, 2009 07:41 PM
hag1128
Jan 27, 2009 08:44 PM
ptelhomme
Oct 21, 2008 09:42 AM
jyoung
May 25, 2008 02:11 PM
snorlax
Apr 7, 2008 02:16 PM
