Need 96 discovery trans advice
Old Oct 5, 2010 | 12:26 PM
harryk30's Avatar
Default Need 96 discovery trans advice
Hello,
I have 1996 discovery. The trans does not upshift after 15-30 minutes driving in the morning. The engine runs fine, there are no trouble codes... The trans fluid is at the proper level.
for the first 15-30 minutes in the morning, it upshifts fine even when going 55mph.
after that it downshift sometimes to 2nd gear or even 1st gear even at 40mph and will stay in that gear.
Sometimes when going 40mph and it has downshifted into 2nd gear, I put it neutral and them into drive, it will upshift to the proper gear... but after about 5-10 minutes it will again downshift into 2nd gear.
If anyone can offer any advice, I would appreciate it.
Thanks,
Harry
Old Oct 5, 2010 | 12:58 PM
NiteTrain's Avatar
obviously heat is the issue here..check transmission cooler, make sure it's cooling properly
Old Oct 5, 2010 | 06:28 PM
I agree a heat and or clogged filter issue.
I assume the trans temp light is not on?
Old Oct 6, 2010 | 08:09 PM
Danny Lee 97 Disco's Avatar
Have you ever dropped the tranny pan and replaced the filter?
abran
Apr 27, 2014 06:59 AM
formel3
Jul 4, 2013 02:17 PM
bradleyd
Jun 14, 2009 07:44 AM
The People Family
Aug 6, 2008 10:32 PM
cushionhead
Aug 14, 2006 06:31 PM
