Need help on 1995 disco...dies intermittently
Old Jan 2, 2013 | 03:27 PM
thechamp3's Avatar
3rd Gear
Default Need help on 1995 disco...dies intermittently
My 95 disco will fire and run but then intermittently die and not re-fire. After I let it sit for a little while it will fire back up and drive. I have done some research and the symptoms match a dying crank position sensor but my 95 doesnt have one only 96 and newer. Anyone have the same issue and a fix?
Old Jan 2, 2013 | 04:08 PM
thechamp3's Avatar
3rd Gear
Just a little more info. I have replaced the plugs and wires, and done a full fluid/filter change. The rig will usually start and run fine for a while but then all of a sudden will die and not re-fire, just crank over and over. It will also not re-fire after being turned off from driving. If i let it sit for a little bit it will then fire and repeat the whole process. Thank in advance for the help.
Old Jan 2, 2013 | 07:26 PM
mmaesner's Avatar
I had a similar thing going last week, mine was corrision (sp) on the fuel pump connector at the fuel pump, you might try some electrical connector cleaner
Old Jan 2, 2013 | 08:15 PM
JPSpen's Avatar
Obviously it cranks. So you're missing either spark or fuel..
Figure out which one and go from there...
John
Old Jan 2, 2013 | 09:19 PM
Bad ignition control amp.
kurtwhitt
Feb 17, 2014 11:40 AM
DISCO1995
Apr 2, 2012 08:31 AM
willie2124
May 12, 2010 10:50 PM
skilley
Dec 12, 2005 09:24 PM
igriego
Jun 6, 2005 04:54 PM
