need a pic of 4x4 shifter In 4H Locker
Old Feb 1, 2011 | 07:59 AM
Ultraquik's Avatar
Default need a pic of 4x4 shifter In 4H Locker
I need a pick of a Disco 1 shifter engaged in 4H Locked. Tried to have a repair shop loosen my shifter and they say it's engaging in locker and I disagree. The shifter will not move left. They shift from neutral down and say it's moved a tad and is in 4H Locked. I think it should move significantly. Please help.
Old Feb 1, 2011 | 10:13 AM
Is this a Rover shop you are using? Does the lock indicator come on over on the left side of you cluster? Have you tried to drive it in a parking lot and turning a tight circle, do the front wheels bind up when trying that? Most likely you have not shifted into either of the lock positions and your linkage is frozen up. This can be cured by a good mechanic who is familiar with the D1 shifters.
Old Feb 1, 2011 | 04:36 PM
Danny Lee 97 Disco's Avatar
Take a look at the pics in the link in my signature for a complete teardown and reassy of a STUCK DIFF LOCK LINKAGE.
Old Feb 2, 2011 | 01:13 PM
Ultraquik's Avatar
It wasn't a Rover shop specifically. It was a Bosch certified shop that specialized I'm German automobiles. They finally got it loose and everything functions properly. Thanks for your help guys.
microbc
Nov 23, 2011 01:54 PM
Brad S1
Oct 29, 2007 03:08 PM
rwp389
Jun 21, 2007 04:11 PM
takar12
Jan 6, 2006 10:38 AM
Hobes
Jun 28, 2005 02:46 PM
