need for spring cones?
If you end up making/buying cones I would stay clear of the RTE ones. Normally RTE is top notch but they missed the mark on their cones; poor design. I have seen more springs fail to reseat using RTE cones than any other brand/design. The RTE cones are too long and not tapered enough. If the springs drops far enough and comes off the cone it is almost certain to not reseat. I would recommend an inverse cone that mounts on the axle. I run the QT ones and they've been great.
![Name: IMAG0113_zps633938f4.jpg
Size: 181.3 KB](https://landroverforums.com/forum/attachments/discovery-i-39/39565d1501372470-need-spring-cones-imag0113_zps633938f4.jpg)
Take a look at the RTE cones, how tall and not tapered they are. In my opinion a shorter cone that comes to a point gives the spring the best chance of relocating properly.
Rear Articulation Cones - Suspension - Rovertym Inc.
