need for spring cones?
Old Oct 15, 2013 | 08:31 PM
TOM R's Avatar
Default need for spring cones?
OK I have a set of 2" lowered shock mounts coming, should I also buy relocation cones?
Do not rock crawl but I like climbing hills, dirt piles etc plus never know what is in the puddles like a big hole or deep ruts
Still run the rear sway for now
Old Oct 15, 2013 | 10:11 PM
honda50r's Avatar
Is your truck lifted?
And if you're running the sway still then definitely not
Old Oct 15, 2013 | 10:44 PM
dusty1's Avatar
yeah, with the sway...no need. but you have seen a set, right? you can fab some up in no time. hb hb
Old Oct 15, 2013 | 10:46 PM
fishEH's Avatar
Install your lowered mounts and run the truck. If your spring pops out, install cones.
Old Oct 16, 2013 | 07:52 AM
TOM R's Avatar
2" one HD springs
Some things I can buy used cheaper then cost of steel and my time , cones sell cheap used,items like a safari basket are worth me fabbing
Old Oct 16, 2013 | 08:53 AM
fishEH's Avatar
If you end up making/buying cones I would stay clear of the RTE ones. Normally RTE is top notch but they missed the mark on their cones; poor design. I have seen more springs fail to reseat using RTE cones than any other brand/design. The RTE cones are too long and not tapered enough. If the springs drops far enough and comes off the cone it is almost certain to not reseat. I would recommend an inverse cone that mounts on the axle. I run the QT ones and they've been great.
Old Oct 16, 2013 | 09:18 AM
TOM R's Avatar
Fish that was my next question, so on the rear the ones on the axle are better if i need them?
Old Oct 16, 2013 | 09:41 AM
fishEH's Avatar
I like the inverse(bottom) cones myself. I have a few different friends that run different variations of inverse cones and all like them.
Take a look at the RTE cones, how tall and not tapered they are. In my opinion a shorter cone that comes to a point gives the spring the best chance of relocating properly.
Rear Articulation Cones - Suspension - Rovertym Inc.
Old Oct 16, 2013 | 09:58 AM
TOM R's Avatar
OK thanks for the info
Locked&Loaded
Feb 20, 2015 07:11 AM
Walko327
Mar 5, 2013 02:00 PM
NPB
Nov 29, 2012 09:44 AM
honda50r
Jul 30, 2012 09:39 PM
AuZZZie
Jun 24, 2011 04:19 PM
