New '96 Disco Owner - Possible Bearing Issue?
Old Sep 5, 2011 | 12:12 PM
  #21
Lchop1.8T's Avatar
Okay, just ordered a set of new u-joints. Sounds like it would be better just to replace them.
Now, on to another issue I have identified. The passenger's side front corner is about 1 inch lower than the rest of the corners of the truck. I measured from the center of the wheel well down to the ground, and it was about an inch shorter than the others. Could this be due to worn springs? I sure hope it is as easy as that. Could there be other factors involved?
BTW, the truck does not have ACE.
Old Sep 5, 2011 | 12:18 PM
  #22
antichrist's Avatar
Is the tire flat on the low side?
Assuming there isn't a lot of weight on one side, yeah, just worn, or possibly broken, spring.
Old Sep 5, 2011 | 01:01 PM
  #23
Lchop1.8T's Avatar
LOL...no, the tire is not flat. I may be a noob to a Disco, but missing that would be down right dumb.
I will be scooting under the truck again today to bleed the brakes. I will make sure to take a look at the springs to see if I can see any signs of wear or sagging.
No other factors could be involved with one corner being lower than the rest, correct?
Thanks - Shawn
Old Sep 14, 2011 | 09:00 AM
  #24
Lchop1.8T's Avatar
Okay, guys. Here is an update.
1. Turns out what I thought was bearing/CV noise, ended up actually being the dust shield scraping on the rotor. So, that turned out better than expected.
2. For the uneven ride height issue, I found out that, for whatever reason, the PO decided to install only one heavy duty spring on the driver's front corner and left the passenger side alone. So, after removing both springs, the driver's side was about an inch longer and the coils were thicker than the passenger side. I ended up replacing both sides with standard springs from Roverland Parts. I plan on doing the rear very soon.
I appreciate everyone's help diagnosing those issues. Now, what I have left to do is:
1. Replace U-joints
2. Replace trans filter and fluid
3. Replace T-stat and coolant
4. Clean throttle body
5. Replace fuel filter
6. Figure out why the rear windows stopped working. Will be pulling the ECU to look at soldering.
All other items on the suggested high-miler list have been completed. Getting close!
Thanks - Shawn
Old Sep 14, 2011 | 10:17 AM
  #25
Danny Lee 97 Disco's Avatar
Maybe the PO was really overweight and his wife was not, thus the one HD spring.
Originally I figured she was the fat one and that spring had seen more wear and tear.
Most Discoveries with the original springs are sagging badly by now. When I first got mine, I could not get underneath the front of it, with the new springs in place, I can roll from one end to the other on my HD creeper.
Run33
May 11, 2015 09:43 PM
Grlica
May 1, 2013 06:13 PM
tuck
Oct 20, 2010 05:33 AM
sidrvvr
Jun 7, 2010 07:22 PM
DiscoTJ
Sep 29, 2009 01:00 PM
